Controlling ODrive from an Arduino via CAN
This page describes how to control an ODrive via CAN using an Arduino and the ODriveArduino library.
The library is compatible with the following setups:
Arduinos with built-in CAN interfaces that use the native Arduino framework (such as Arduino UNO R4 Minima, Arduino UNO R4 WiFi and others)
Teensys with built-in CAN interfaces that are compatibly with FlexCAN_T4 (Teensy 4.0, Teensy 4.1)
Arduino-compatible boards with MCP2515-based CAN shields
This library is primarily intended for runtime usage, such as changing states, sending setpoints and reading position/velocity feedback. While the CAN protocol allows for the modification of any configuration variable, this is often much easier to accomplish in the ODrive GUI or the odrivetool. More information about the underlying protocol can be found here.
Connecting the Arduino to the ODrive
First, connect your Arduino to the ODrive. Below you see an example setup. Your setup may look different depending on your hardware, please see the notes below.
Arduino connected to ODrive S1 via CAN. Click to enlarge.
The Arduino UNO R4 Minima shown on this picture has a built-in CAN interface but no CAN transceiver. That means we need an external transceiver.
The CAN transceiver on this picture is a Waveshare SN65HVD230 CAN Board.
CAN bus ground must be connected to DC- at one single point in the system. On this picture, this is done with a single wire on the ODrive’s second CAN connector. See Hardware Setup for more details.
If you’re using multiple ODrives you can simply daisy-chain them together.
When using an ODrive Pro, it must be powered through DC+/- to be able to communicate via CAN.
Configuring the ODrive
Next, configure your ODrive according to your application. The easiest way to do this for the first time is via USB in the Web GUI.
It is possible to set up a fresh ODrive purely via CAN, however this is currently not possible from the GUI and requires scripting instead. See Arbitrary Parameter Access for more info.
Connect your ODrive to your PC via a USB isolator, open the Web GUI and follow the Configuration wizard.
Most settings depend on your hardware so we won’t go into detail here. However there are a few settings specifically needed for this example:
Control Mode page: Select Filtered Position Control mode with a bandwidth of 100 rad/s.
odrv0.axis0.controller.config.control_mode = ControlMode.POSITION_CONTROL odrv0.axis0.controller.config.input_mode = InputMode.POS_FILTER odrv0.axis0.controller.config.input_filter_bandwidth = 20
Interfaces page: Enable CAN, enable feedback messages and set the Node ID to 0 (or something unique for every ODrive if you have multiple).
Optionally you can also enable the watchdog (also on the Interfaces page). This will make the ODrive stop when the CAN connection gets disrupted.
When you’re done configuring, go to the Dashboard to verify that you can send position setpoints from the GUI before proceeding with the next steps.
If you have already enabled CAN and come back to this step to change something, make sure to disable CAN first or disconnect/unpower the Arduino. Otherwise the Arduino sketch might interfer with the GUI.
Installing the ODriveArduino Library
Open your Arduino IDE.
Go to Sketch > Include Library > Manage Libraries.
In the Library Manager, type “ODriveArduino” into the search box.
Click on the entry for the ODriveArduino library, then click “Install”.
Example Sketch
Finally, upload the following example sketch to the Arduino. You can also find this under File > Examples > ODriveArduino. This example will put the ODrive into closed loop control and then move the motor back and forth in a sine wave pattern.
1#include <Arduino.h>
2#include "ODriveCAN.h"
3
4// Documentation for this example can be found here:
5// https://docs.odriverobotics.com/v/latest/guides/arduino-can-guide.html
6
7
8/* Configuration of example sketch -------------------------------------------*/
9
10// CAN bus baudrate. Make sure this matches for every device on the bus
11#define CAN_BAUDRATE 250000
12
13// ODrive node_id for odrv0
14#define ODRV0_NODE_ID 0
15
16// Uncomment below the line that corresponds to your hardware.
17// See also "Board-specific settings" to adapt the details for your hardware setup.
18
19// #define IS_TEENSY_BUILTIN // Teensy boards with built-in CAN interface (e.g. Teensy 4.1). See below to select which interface to use.
20// #define IS_ARDUINO_BUILTIN // Arduino boards with built-in CAN interface (e.g. Arduino Uno R4 Minima)
21// #define IS_MCP2515 // Any board with external MCP2515 based extension module. See below to configure the module.
22// #define IS_STM32_BUILTIN // STM32 boards with built-in CAN interface (e.g. STM32F4 Discovery).
23// #define IS_ESP32_TWAI // ESP32 boards with built-in TWAI (CAN) interface. Directly uses the ESP-IDF TWAI driver.
24
25
26/* Board-specific includes ---------------------------------------------------*/
27
28#if defined(IS_TEENSY_BUILTIN) + defined(IS_ARDUINO_BUILTIN) + defined(IS_MCP2515) + defined(IS_STM32_BUILTIN) + defined(IS_ESP32_TWAI) != 1
29#warning "Select exactly one hardware option at the top of this file."
30
31#if CAN_HOWMANY > 0 || CANFD_HOWMANY > 0
32#define IS_ARDUINO_BUILTIN
33#warning "guessing that this uses HardwareCAN"
34#else
35#error "cannot guess hardware version"
36#endif
37
38#endif
39
40#ifdef IS_ARDUINO_BUILTIN
41// See https://github.com/arduino/ArduinoCore-API/blob/master/api/HardwareCAN.h
42// and https://github.com/arduino/ArduinoCore-renesas/tree/main/libraries/Arduino_CAN
43
44#include <Arduino_CAN.h>
45#include <ODriveHardwareCAN.hpp>
46#endif // IS_ARDUINO_BUILTIN
47
48#ifdef IS_MCP2515
49// See https://github.com/sandeepmistry/arduino-CAN/
50#include "MCP2515.h"
51#include "ODriveMCPCAN.hpp"
52#endif // IS_MCP2515
53
54#ifdef IS_TEENSY_BUILTIN
55// See https://github.com/tonton81/FlexCAN_T4
56// clone https://github.com/tonton81/FlexCAN_T4.git into /src
57#include <FlexCAN_T4.h>
58#include "ODriveFlexCAN.hpp"
59struct ODriveStatus; // hack to prevent teensy compile error
60#endif // IS_TEENSY_BUILTIN
61
62#ifdef IS_STM32_BUILTIN
63// See https://github.com/pazi88/STM32_CAN
64#include <STM32_CAN.h>
65#include "ODriveSTM32CAN.hpp"
66#endif // IS_STM32_BUILTIN
67
68#ifdef IS_ESP32_TWAI
69// See https://docs.espressif.com/projects/esp-idf/en/stable/esp32/api-reference/peripherals/twai.html
70#include "driver/twai.h"
71#include "ODriveESP32TWAI.hpp"
72#endif // IS_ESP32_TWAI
73
74
75
76/* Board-specific settings ---------------------------------------------------*/
77
78
79/* Teensy */
80
81#ifdef IS_TEENSY_BUILTIN
82
83FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can_intf;
84
85bool setupCan() {
86 can_intf.begin();
87 can_intf.setBaudRate(CAN_BAUDRATE);
88 can_intf.setMaxMB(16);
89 can_intf.enableFIFO();
90 can_intf.enableFIFOInterrupt();
91 can_intf.onReceive(onCanMessage);
92 return true;
93}
94
95#endif // IS_TEENSY_BUILTIN
96
97
98/* MCP2515-based extension modules -*/
99
100#ifdef IS_MCP2515
101
102MCP2515Class& can_intf = CAN;
103
104// chip select pin used for the MCP2515
105#define MCP2515_CS 10
106
107// interrupt pin used for the MCP2515
108// NOTE: not all Arduino pins are interruptable, check the documentation for your board!
109#define MCP2515_INT 2
110
111// freqeuncy of the crystal oscillator on the MCP2515 breakout board.
112// common values are: 16 MHz, 12 MHz, 8 MHz
113#define MCP2515_CLK_HZ 8000000
114
115
116static inline void receiveCallback(int packet_size) {
117 if (packet_size > 8) {
118 return; // not supported
119 }
120 CanMsg msg = {.id = (unsigned int)CAN.packetId(), .len = (uint8_t)packet_size};
121 CAN.readBytes(msg.buffer, packet_size);
122 onCanMessage(msg);
123}
124
125bool setupCan() {
126 // configure and initialize the CAN bus interface
127 CAN.setPins(MCP2515_CS, MCP2515_INT);
128 CAN.setClockFrequency(MCP2515_CLK_HZ);
129 if (!CAN.begin(CAN_BAUDRATE)) {
130 return false;
131 }
132
133 CAN.onReceive(receiveCallback);
134 return true;
135}
136
137#endif // IS_MCP2515
138
139
140/* Arduinos with built-in CAN */
141
142#ifdef IS_ARDUINO_BUILTIN
143
144HardwareCAN& can_intf = CAN;
145
146bool setupCan() {
147 return can_intf.begin((CanBitRate)CAN_BAUDRATE);
148}
149
150#endif
151
152
153/* STM32 boards with built-in CAN */
154
155#ifdef IS_STM32_BUILTIN
156
157STM32_CAN Can1( CAN1 );
158STM32_CAN& can_intf = Can1;
159
160bool setupCan() {
161 can_intf.begin();
162 can_intf.setBaudRate(CAN_BAUDRATE);
163 return true;
164}
165
166#endif // IS_STM32_BUILTIN
167
168
169/* ESP32 boards with built-in TWAI (CAN) */
170
171#ifdef IS_ESP32_TWAI
172
173// Pins used to connect to CAN bus transceiver
174#define ESP32_TWAI_TX_PIN 26
175#define ESP32_TWAI_RX_PIN 25
176
177ESP32TWAIIntf can_intf;
178
179bool setupCan() {
180 twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(
181 (gpio_num_t)ESP32_TWAI_TX_PIN,
182 (gpio_num_t)ESP32_TWAI_RX_PIN,
183 TWAI_MODE_NORMAL
184 );
185
186 twai_timing_config_t t_config;
187 switch (CAN_BAUDRATE) {
188 case 1000000: t_config = TWAI_TIMING_CONFIG_1MBITS(); break;
189 case 800000: t_config = TWAI_TIMING_CONFIG_800KBITS(); break;
190 case 500000: t_config = TWAI_TIMING_CONFIG_500KBITS(); break;
191 case 250000: t_config = TWAI_TIMING_CONFIG_250KBITS(); break;
192 case 125000: t_config = TWAI_TIMING_CONFIG_125KBITS(); break;
193 case 100000: t_config = TWAI_TIMING_CONFIG_100KBITS(); break;
194 case 50000: t_config = TWAI_TIMING_CONFIG_50KBITS(); break;
195 case 25000: t_config = TWAI_TIMING_CONFIG_25KBITS(); break;
196 default: t_config = TWAI_TIMING_CONFIG_250KBITS(); break;
197 }
198
199 twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL();
200
201 if (twai_driver_install(&g_config, &t_config, &f_config) != ESP_OK) {
202 return false;
203 }
204
205 if (twai_start() != ESP_OK) {
206 twai_driver_uninstall();
207 return false;
208 }
209
210 return true;
211}
212
213#endif // IS_ESP32_TWAI
214
215
216/* Example sketch ------------------------------------------------------------*/
217
218// Instantiate ODrive objects
219ODriveCAN odrv0(wrap_can_intf(can_intf), ODRV0_NODE_ID); // Standard CAN message ID
220ODriveCAN* odrives[] = {&odrv0}; // Make sure all ODriveCAN instances are accounted for here
221
222struct ODriveUserData {
223 Heartbeat_msg_t last_heartbeat;
224 bool received_heartbeat = false;
225 Get_Encoder_Estimates_msg_t last_feedback;
226 bool received_feedback = false;
227};
228
229// Keep some application-specific user data for every ODrive.
230ODriveUserData odrv0_user_data;
231
232// Called every time a Heartbeat message arrives from the ODrive
233void onHeartbeat(Heartbeat_msg_t& msg, void* user_data) {
234 ODriveUserData* odrv_user_data = static_cast<ODriveUserData*>(user_data);
235 odrv_user_data->last_heartbeat = msg;
236 odrv_user_data->received_heartbeat = true;
237}
238
239// Called every time a feedback message arrives from the ODrive
240void onFeedback(Get_Encoder_Estimates_msg_t& msg, void* user_data) {
241 ODriveUserData* odrv_user_data = static_cast<ODriveUserData*>(user_data);
242 odrv_user_data->last_feedback = msg;
243 odrv_user_data->received_feedback = true;
244}
245
246// Called for every message that arrives on the CAN bus
247void onCanMessage(const CanMsg& msg) {
248 for (auto odrive: odrives) {
249 onReceive(msg, *odrive);
250 }
251}
252
253void setup() {
254 Serial.begin(115200);
255
256 // Wait for up to 3 seconds for the serial port to be opened on the PC side.
257 // If no PC connects, continue anyway.
258 for (int i = 0; i < 30 && !Serial; ++i) {
259 delay(100);
260 }
261 delay(200);
262
263
264 Serial.println("Starting ODriveCAN demo");
265
266 // Register callbacks for the heartbeat and encoder feedback messages
267 odrv0.onFeedback(onFeedback, &odrv0_user_data);
268 odrv0.onStatus(onHeartbeat, &odrv0_user_data);
269
270 // Configure and initialize the CAN bus interface. This function depends on
271 // your hardware and the CAN stack that you're using.
272 if (!setupCan()) {
273 Serial.println("CAN failed to initialize: reset required");
274 while (true); // spin indefinitely
275 }
276
277 Serial.println("Waiting for ODrive...");
278 while (!odrv0_user_data.received_heartbeat) {
279 pumpEvents(can_intf);
280 }
281
282 Serial.println("found ODrive");
283
284 // request bus voltage and current (1sec timeout)
285 Serial.println("attempting to read bus voltage and current");
286 Get_Bus_Voltage_Current_msg_t vbus;
287 if (!odrv0.request(vbus, 1000)) {
288 Serial.println("vbus request failed!");
289 while (true); // spin indefinitely
290 }
291
292 Serial.print("DC voltage [V]: ");
293 Serial.println(vbus.Bus_Voltage);
294 Serial.print("DC current [A]: ");
295 Serial.println(vbus.Bus_Current);
296
297 Serial.println("Enabling closed loop control...");
298 while (odrv0_user_data.last_heartbeat.Axis_State != ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL) {
299 odrv0.clearErrors();
300 delay(1);
301 odrv0.setState(ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL);
302
303 // Pump events for 150ms. This delay is needed for two reasons;
304 // 1. If there is an error condition, such as missing DC power, the ODrive might
305 // briefly attempt to enter CLOSED_LOOP_CONTROL state, so we can't rely
306 // on the first heartbeat response, so we want to receive at least two
307 // heartbeats (100ms default interval).
308 // 2. If the bus is congested, the setState command won't get through
309 // immediately but can be delayed.
310 for (int i = 0; i < 15; ++i) {
311 delay(10);
312 pumpEvents(can_intf);
313 }
314 }
315
316 Serial.println("ODrive running!");
317}
318
319void loop() {
320 pumpEvents(can_intf); // This is required on some platforms to handle incoming feedback CAN messages
321 // Note that on MCP2515-based platforms, this will delay for a fixed 10ms.
322 //
323 // This has been found to reduce the number of dropped messages, however it can be removed
324 // for applications requiring loop times over 100Hz.
325
326 float SINE_PERIOD = 2.0f; // Period of the position command sine wave in seconds
327
328 float t = 0.001 * millis();
329
330 float phase = t * (TWO_PI / SINE_PERIOD);
331
332 odrv0.setPosition(
333 sin(phase), // position
334 cos(phase) * (TWO_PI / SINE_PERIOD) // velocity feedforward (optional)
335 );
336
337 // print position and velocity for Serial Plotter
338 if (odrv0_user_data.received_feedback) {
339 Get_Encoder_Estimates_msg_t feedback = odrv0_user_data.last_feedback;
340 odrv0_user_data.received_feedback = false;
341 Serial.print("odrv0-pos:");
342 Serial.print(feedback.Pos_Estimate);
343 Serial.print(",");
344 Serial.print("odrv0-vel:");
345 Serial.println(feedback.Vel_Estimate);
346 }
347}
Below is the expected output in the Arduino IDE’s Serial Monitor (Tools > Serial Monitor):
found ODrive
DC voltage [V]: 17.31
DC current [A]: 0.00
ODrive running!
odrv0-pos:0.72,odrv0-vel:0.01
odrv0-pos:0.72,odrv0-vel:-0.01
odrv0-pos:0.65,odrv0-vel:-11.80
odrv0-pos:0.55,odrv0-vel:-9.42
odrv0-pos:0.45,odrv0-vel:-10.08
odrv0-pos:0.35,odrv0-vel:-9.88
odrv0-pos:0.25,odrv0-vel:-10.03
odrv0-pos:0.15,odrv0-vel:-9.91
odrv0-pos:0.05,odrv0-vel:-10.02
odrv0-pos:-0.05,odrv0-vel:-9.95
odrv0-pos:-0.15,odrv0-vel:-10.03
odrv0-pos:-0.25,odrv0-vel:-9.94
odrv0-pos:-0.35,odrv0-vel:-9.98
And here’s the Serial Plotter (Tools > Serial Plotter):
Arduino hangs at Waiting for ODrive...
This means the Arduino is not receiving heartbeat messages from the ODrive.
Make sure heartbeat messages are enabled according to Configuring the ODrive.
Make sure the configured CAN baudrate of the ODrive and the Arduino sketch match. The default for the Arduino sketch is 250000 while the ODrive uses automatic baudrate detection by default since firmware version 0.6.11. On earlier firmware versions, the ODrive default is also 250000.
Likewise, make sure the configured Node ID matches between ODrive and Arduino sketch. The default is 0 for both.
Double check your wiring.
In the example sketch, in the
onMessage()function, insert aSerial.println()statement. This can help you debug if your Arduino is receiving any CAN messages at all.If you have an oscilloscope, CAN logger or CAN-to-USB dongle, use them to check if there are any CAN messages on the bus.
Arduino hangs at Enabling closed loop control...
This means that the Arduino can talk to the ODrive and vice versa, but the ODrive refuses to enter closed loop control mode.
This can have lots of reasons (ODrive unpowered, ODrive not calibrated, etc.). The easiest way to find out why, is to open the GUI and check the status bar.
Arduino Library Reference
class ODriveCAN
Public Functions
bool clearErrors()
Clear all errors on the ODrive.
This function returns immediately and does not check if the ODrive received the CAN message.
bool setState(ODriveAxisState requested_state)
Tells the ODrive to change its axis state.
bool setControllerMode(uint8_t control_mode, uint8_t input_mode)
Sets the control mode and input mode of the ODrive.
bool setPosition(float position, float velocity_feedforward = 0.0f, float torque_feedforward = 0.0f)
Sends a position setpoint with optional velocity and torque feedforward.
bool setVelocity(float velocity, float torque_feedforward = 0.0f)
Sends a velocity setpoint with optional torque feedforward.
bool setTorque(float torque)
Sends a torque setpoint to the ODrive.
bool setLimits(float velocity_limit, float current_soft_max)
Sets the velocity and current limits.
bool setPosGain(float pos_gain)
Sets the position gain.
bool setVelGains(float vel_gain, float vel_integrator_gain)
Sets the velocity and velocity integrator gains.
bool setAbsolutePosition(float abs_pos)
Sets the encoder’s absolute position and enables absolute positioning.
bool setTrapezoidalVelLimit(float vel_limit)
Sets the coast velocity for subsequent trapezoidal moves.
bool setTrapezoidalAccelLimits(float accel_limit, float decel_limit)
Sets the acceleration and deceleration values for subsequent trapezoidal moves.
bool getCurrents(Get_Iq_msg_t &msg, uint16_t timeout_ms = 10)
Requests motor current. Iq_measured represents torque-generating current.
This function will block and wait for up to timeout_ms (default 10msec) for ODrive to reply
bool getTemperature(Get_Temperature_msg_t &msg, uint16_t timeout_ms = 10)
Requests motor temperature.
bool getError(Get_Error_msg_t &msg, uint16_t timeout_ms = 10)
Requests error information.
bool getVersion(Get_Version_msg_t &msg, uint16_t timeout_ms = 10)
Requests hardware and firmware version information.
bool getFeedback(Get_Encoder_Estimates_msg_t &msg, uint16_t timeout_ms = 10)
Requests encoder feedback data.
bool getBusVI(Get_Bus_Voltage_Current_msg_t &msg, uint16_t timeout_ms = 10)
Requests ODrive DC bus voltage and current.
This function will block and wait for up to timeout_ms (default 10msec) for ODrive to reply May trigger onBusVI callback if it’s registered.
bool getPower(Get_Powers_msg_t &msg, uint16_t timeout_ms = 10)
Requests mechanical and electrical power data (used for spinout detection)
bool reset(ResetAction action = ResetAction::Reboot)
Resets the ODrive with the given action.
Valid actions:
Reboot (0)
Save (1)
Erase (2)
inline void onFeedback(void (*callback)(Get_Encoder_Estimates_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive feedback processing.
inline void onStatus(void (*callback)(Heartbeat_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive axis state feedback.
inline void onTorques(void (*callback)(Get_Torques_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive torques feedback processing.
inline void onTemperature(void (*callback)(Get_Temperature_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive temperature feedback.
inline void onBusVI(void (*callback)(Get_Bus_Voltage_Current_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive bus voltage/current feedback.
inline void onCurrents(void (*callback)(Get_Iq_msg_t &feedback, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive currents feedback.
inline void onError(void (*callback)(Get_Error_msg_t &msg, void *user_data), void *user_data = nullptr)
Registers a callback for ODrive error messages.
void onReceive(uint32_t id, uint8_t length, const uint8_t *data)
Processes received CAN messages for the ODrive.
template<typename T>
inline bool request(T &msg, uint16_t timeout_ms = 10) Sends a request message and awaits a response.
Blocks until the response is received or the timeout is reached. Returns false if the ODrive does not respond within the specified timeout.
inline T getEndpoint(uint16_t endpoint_id, uint16_t timeout_ms = 10) Get value at the endpoint.
- Template Parameters:
T – The data type expected from the endpoint
- Parameters:
endpoint_id – Unique ID from flat_endpoints.json
timeout_ms – Time to wait for a response from ODrive
- Returns:
T Data from the endpoint, or 0 on timeout
inline bool setEndpoint(uint16_t endpoint_id, T value) Set endpoint to value.
T – Type of the value from flat_endpoints.json
- Parameters:
endpoint_id – Unique ID of endpoint from flat_endpoints.json
value – value to write to the endpoint
bool clearErrors()
