CAN Protocol
This document describes the CAN Protocol. For examples of usage, check out our CAN Bus Guide.
  • The ODrive CANSimple protocol uses standard 11-bit message identifiers.
    CANSimple Message ID
  • Messages prefixed with Set_ are messages that the host can send to the ODrive.
  • Messages prefixed with Get_ are messages that the ODrive can send to the host. These messages can be enabled as Cyclic Messages or requested explicitly by the master. To explicitly request a message, the master sends a message with the RTR bit set, and the ODrive responds with the same ID and corresponding payload. (A message with of RTR=0 and an empty payload can also be used, but is susceptible to collisions with the ODrive’s response.)
  • All values are encoded in little endian (aka Intel format, aka least significant byte first).
  • Floats are encoded with the standard IEEE 754 Float format.
  • Reserved fields and padding in Host → ODrive messages must be set to 0.
  • Reserved fields and padding in ODrive → Host messages must be ignored.
  • Beyond the predefined messages below, all parameters and functions of the ODrive are accessible via RxSdo / TxSdo. See Arbitrary Parameter Access for examples.
CAN Messages - click on the message name for details
CMD ID
Name
Direction
Signals
0x000
Get_Version
ODrive → Host
Protocol_Version
Hw_Version_Major
Hw_Version_Minor
Hw_Version_Variant
Fw_Version_Major
Fw_Version_Minor
Fw_Version_Revision
Fw_Version_Unreleased
0x001
Heartbeat
ODrive → Host
Axis_Error
Axis_State
Procedure_Result
Trajectory_Done_Flag
0x002
Estop
Host → ODrive
0x003
Get_Error
ODrive → Host
Active_Errors
Disarm_Reason
0x004
RxSdo
Host → ODrive
Opcode
Endpoint_ID
Reserved
Value
0x005
TxSdo
ODrive → Host
Reserved0
Endpoint_ID
Reserved1
Value
0x006
Address
Host → ODrive, ODrive → Host
Node_ID
Serial_Number
Connection_ID
0x007
Set_Axis_State
Host → ODrive
Axis_Requested_State
0x009
Get_Encoder_Estimates
ODrive → Host
Pos_Estimate
Vel_Estimate
0x00b
Set_Controller_Mode
Host → ODrive
Control_Mode
Input_Mode
0x00c
Set_Input_Pos
Host → ODrive
Input_Pos
Vel_FF
Torque_FF
0x00d
Set_Input_Vel
Host → ODrive
Input_Vel
Input_Torque_FF
0x00e
Set_Input_Torque
Host → ODrive
Input_Torque
0x00f
Set_Limits
Host → ODrive
Velocity_Limit
Current_Limit
0x011
Set_Traj_Vel_Limit
Host → ODrive
Traj_Vel_Limit
0x012
Set_Traj_Accel_Limits
Host → ODrive
Traj_Accel_Limit
Traj_Decel_Limit
0x013
Set_Traj_Inertia
Host → ODrive
Traj_Inertia
0x014
Get_Iq
ODrive → Host
Iq_Setpoint
Iq_Measured
0x015
Get_Temperature
ODrive → Host
FET_Temperature
Motor_Temperature
0x016
Reboot
Host → ODrive
Action
0x017
Get_Bus_Voltage_Current
ODrive → Host
Bus_Voltage
Bus_Current
0x018
Clear_Errors
Host → ODrive
Identify
0x019
Set_Absolute_Position
Host → ODrive
Position
0x01a
Set_Pos_Gain
Host → ODrive
Pos_Gain
0x01b
Set_Vel_Gains
Host → ODrive
Vel_Gain
Vel_Integrator_Gain
0x01c
Get_Torques
ODrive → Host
Torque_Target
Torque_Estimate
0x01d
Get_Powers
ODrive → Host
Electrical_Power
Mechanical_Power
0x01f
Enter_DFU_Mode
Host → ODrive
Cyclic Messages
The ODrive can be configured to send some messages periodically without a request from the host. This is done by setting the desired send intervals in <odrv>.axis.config.can. An interval of 0 disables the message. If the ODrive is unaddressed (node_id = 0x3f), all cyclic messages are disabled regardless of their configured interval.
Message
Configuration (<odrv>.axis.config.can.[...])
Default Interval
Heartbeat
heartbeat_msg_rate_ms
100 ms
encoder_msg_rate_ms
10 ms
Get_Iq
iq_msg_rate_ms
disabled
Get_Error
error_msg_rate_ms
disabled
Get_Temperature
temperature_msg_rate_ms
disabled
bus_voltage_msg_rate_ms
disabled
Get_Torques
torques_msg_rate_ms
disabled
Get_Powers
powers_msg_rate_ms
disabled
Get_Version
version_msg_rate_ms
disabled
Watchdog
The ODrive’s watchdog timer can be used as a safety feature to disable the motor when CAN communication is disrupted.
See axis.config.enable_watchdog on how to enable the watchdog timer.
The watchdog is reset by every Set_Input_Pos, Set_Input_Vel and Set_Input_Torque message, as well as when entering CLOSED_LOOP_CONTROL through Set_Axis_State.
Baudrate & Autobaud
The ODrive’s baudrate (can.config.baud_rate) can either be explicitly configured by the user or left at 0 (default) to enable automatic baudrate detection (new in Firmware 0.6.11).
When using automatic baudrate detection, the ODrive starts in a “scanning mode” where it does not handle any CAN commands and does not send any CAN messages, but relies on incoming CAN traffic to detect the baudrate. For quick initialization, users are recommended to send a “beacon message” (any message ID / payload) at 10Hz or faster.
Once the scan completes, the ODrive responds normally to CAN messages and sends Cyclic Messages if applicable.
When the ODrive runs into a bus-off condition, it drops back into scanning mode.
In production systems it is recommended to configure the baudrate explicitily to guarantee deterministic startup time.
Supported baudrates for autodetection: 40kbps, 125kbps, 250kbps, 500kbps, 1Mbps.
Bit Timing
The ODrive uses the following fixed bit timing parameters for all baudrates, for both nominal and data phases:
  • Bit length: 8 time quanta (1 sync + 6 propagation/phase1 + 1 phase2)
  • Sample point: 87.5%
  • Synchronization Jump Width (SJW): 1 time quantum
CAN-FD
⇒ New in Firmware 0.6.10
ODrive Pro, S1 and Micro support CAN-FD. Classic CAN and CAN-FD frames can be mixed on the same bus, provided that all other bus nodes tolerate CAN-FD traffic.
  • Receiving: To receive CAN-FD frames with the Bit Rate Switch (BRS) flag set, you must set can.config.data_baud_rate.
  • Transmitting: By default, the ODrive sends all of its messages as Classic CAN frames. Set can.config.tx_brs to True to send all messages as CAN-FD frames.
Usage notes:
  • The CANSimple protocol is identical over Classic CAN and CAN-FD; all message payloads fit within 8 bytes, and the larger payload sizes of CAN-FD are currently not supported or utilized.
  • The CAN-FD frame format does not support the RTR bit. Hosts that transmit exclusively in CAN-FD format can request Get_ messages by sending a data frame with an empty payload instead (see Overview).
  • The data phase baudrate is not covered by automatic baudrate detection. When using BRS, all nodes must be explicitly configured to the same data baudrate. The maximum supported data baudrate depends on the hardware, see can.config.data_baud_rate for details.
  • The bit timing parameters above apply to the data phase as well.
Since can.config.data_baud_rate defaults to 0 and is not autodetected, an unconfigured ODrive cannot join a bus that carries BRS traffic. Commissioning a new ODrive and firmware update over CAN therefore require temporarily stopping all BRS traffic on the bus.
Firmware versions 0.6.10 and 0.6.11 could run into spurious bus-off events when CAN-FD frames were present on the bus. Firmware version 0.6.12 or newer is recommended when using CAN-FD.
Broadcast
⇒ New in Firmware 0.6.9
The node ID 0x3f is a special broadcast address. When the host sends a message with this ID, it is received by all ODrives on the bus. If the broadcast message yields a response (typically Get_ messages with RTR=1), each ODrive responds with its own node_id.
If an ODrive is configured with node_id = 0x3f, it does not send out any cyclic messages or responses, except for the special message Address.
Discovery & Addressing
By default, an unconfigured ODrive starts with node_id = 0x3f, which represents an unaddressed state. In this state the ODrive does not send any cyclic messages (heartbeats, feedback, …).
The node ID can be configured:
  • Over USB using odrivetool or in the GUI.
  • Via CAN using automatic enumeration based on the Address (0x06) message. An interactive script for this is provided in Setting up the ODrive (CAN only) which should be sufficient for most commissioning scenarios.
    Otherwise, a user application can implement its own procedure based on the use cases below.
Use cases:
  • Enumerate all ODrives on the bus:
    Send (node_id = 0x3f, cmd_id = 0x06, RTR=1).
    All ODrives that are already addressed (node_id != 0x3f) will respond immediately with their serial number and node_id.
    All unaddressed ODrives (node_id == 0x3f) will respond after a small random delay, averaging 250 ms between each message.
  • Assign a new node ID (N) to an ODrive with unknown node ID and known serial number (SN):
    Send (node_id = 0x3f, cmd_id = 0x06, Node_ID = N, Serial_Number = SN).
    If the ODrive was at its default configuration, it will now start periodically sending Heartbeat and Get_Encoder_Estimates messages.
  • Assign a new node ID (new_N) to an ODrive with known node ID (old_N) and unknown serial number:
    Send (node_id = old_N, cmd_id = 0x06, Node_ID = new_N, Serial_Number = 0).
Furthermore, the Identify field in Clear_Errors can be used to blink the status LED. This allows for setting up an interactive procedure that lets the user associate newly discovered unconfigured ODrives with their location in a multi-axis robot.
Bus-off handling
“Bus-off” events are part of the CAN specification and are usually the result of a persistent fault condition on the CAN bus (e.g. short, disconnect or faulty bus node).
When the ODrive encounters a bus-off event, it reacts as follows:
  • if autobaud is enabled: Drops into scanning mode.
  • if autobaud is disabled: Restarts its CAN interface. If the fault condition persists, the CAN interface is restarted repeatedly. See also n_restarts.
DBC Files
DBC files are machine-readable database files that describe CAN message formats.
The CANSimple .dbc file for each firmware version can be downloaded here.
Several tools and libraries exist to ingest DBC files. For example you can use the free CANdb++ software from Vector to view the database.
Interoperability with CANopen
ODrives can coexist with CANopen devices on the same bus if caution is taken with the node ID assignment.
The following table lists the valid combinations of node IDs for both CANopen and CANsimple.
CANOpen node IDs
ODrive CANSimple node IDs
32 … 127
0x10, 0x18, 0x20, 0x28
64 … 127
0x10, 0x11, 0x18, 0x19, 0x20, 0x21, 0x28, 0x29
96 … 127
0x10, 0x11, 0x12, 0x18, 0x19, 0x1A, 0x20, 0x21, 0x22, 0x28, 0x29, 0x2A
Messages
Get_Version
  • Command ID: 0x00
  • Direction: ODrive → Host
Start Byte
Name
Type
Description
0
Protocol_Version
uint8
Always reported as 2
Hw_Version_Major
uint8
hw_version_major
2
Hw_Version_Minor
uint8
hw_version_minor
3
Hw_Version_Variant
uint8
hw_version_variant
4
Fw_Version_Major
uint8
fw_version_major
5
Fw_Version_Minor
uint8
fw_version_minor
6
Fw_Version_Revision
uint8
fw_version_revision
7
uint8
fw_version_unreleased
Heartbeat
  • Command ID: 0x01
Start Byte
Name
Type
Description
0
Axis_Error
uint32
<axis>.active_errors | <axis>.disarm_reason
4
Axis_State
uint8
<axis>.current_state
5
Procedure_Result
uint8
<axis>.procedure_result
6
uint8
<axis>.controller.trajectory_done (0: false, 1: true)
Estop
  • Command ID: 0x02
  • Direction: Host → ODrive
  • Empty Payload
Causes the axis to disarm with ESTOP_REQUESTED.
Get_Error
  • Command ID: 0x03
Start Byte
Name
Type
Description
0
Active_Errors
uint32
active_errors
4
Disarm_Reason
uint32
disarm_reason
RxSdo
  • Command ID: 0x04
Start Byte
Name
Type
Description
0
Opcode
uint8
0: read, 1: write
Endpoint_ID
uint16
Endpoint ID as found in flat_endpoints.json
3
Reserved
uint8
Must be set to 0
4
Value
uint32
Data type and length depend on endpoint ID
Sent by the host to read or write from/to arbitrary parameters. See Arbitrary Parameter Access for details.
TxSdo
  • Command ID: 0x05
Start Byte
Name
Type
Description
0
Reserved0
uint8
Must be ignored by host
Endpoint_ID
uint16
3
Reserved1
uint8
4
Value
uint32
Sent by the ODrive in response to any RxSdo. See Arbitrary Parameter Access for details.
Address
  • Command ID: 0x06
  • Direction: Host → ODrive, ODrive → Host
Start Byte
Name
Type
Description
0
Node_ID
uint8
node_id
Serial_Number
uint48
ODrive → Host: Serial number of the sending ODrive
Host → ODrive: The serial number that shall be associated with the specified Node_ID
7
Connection_ID
uint8
Connection ID. Can be left 0
Main section: Discovery & Addressing.
When an ODrive receives this message (subject to receive filters, that means node_id contained in the message ID must matches its own or be 0x3f), it takes the following action:
  • RTR=1 (or empty payload): Respond with own serial number and node_id.
  • Matching Serial_Number: Take on the new Node_ID.
  • Mismatching Serial_Number but matching Node_ID: Go to unaddressed state (node_id = 0x3f).
  • Mismatching Serial_Number and mismatching Node_ID: Ignore message.
Serial_Number == 0 is considered a wildcard that always matches.
Responses on this message are sent even if the ODrive is unaddressed (node_id = 0x3f). In this case, the response is sent after a random delay to avoid collisions.
Set_Axis_State
  • Command ID: 0x07
Start Byte
Name
Type
Description
0
uint32
requested_state
  • Command ID: 0x09
Start Byte
Name
Type
Unit
Description
0
Pos_Estimate
float32
rev
<axis>.pos_vel_mapper.pos_rel or <axis>.pos_vel_mapper.pos_abs,
depending on ODrive.Controller.Config.absolute_setpoints
4
Vel_Estimate
float32
rev/s
<axis>.pos_vel_mapper.vel
This message is sent by the ODrive periodically by default. See also Cyclic Messages.
Set_Controller_Mode
  • Command ID: 0x0b
Start Byte
Name
Type
Description
0
Control_Mode
uint32
control_mode
4
Input_Mode
uint32
input_mode
Set_Input_Pos
  • Command ID: 0x0c
Start Byte
Name
Type
Unit
Description
0
Input_Pos
float32
rev
input_pos
4
Vel_FF
int16
0.001 rev/s (default) [1]
input_vel
6
Torque_FF
int16
0.001 Nm (default) [2]
input_torque
Set_Input_Vel
  • Command ID: 0x0d
Start Byte
Name
Type
Unit
Description
0
Input_Vel
float32
rev/s
input_vel
4
Input_Torque_FF
float32
Nm
input_torque
Set_Input_Torque
  • Command ID: 0x0e
Start Byte
Name
Type
Unit
Description
0
Input_Torque
float32
Nm
input_torque
Set_Limits
  • Command ID: 0x0f
Start Byte
Name
Type
Unit
Description
0
Velocity_Limit
float32
rev/s
vel_limit
4
Current_Limit
float32
A
current_soft_max
Set_Traj_Vel_Limit
  • Command ID: 0x11
Start Byte
Name
Type
Unit
Description
0
Traj_Vel_Limit
float32
rev/s
vel_limit
  • Command ID: 0x12
Start Byte
Name
Type
Unit
Description
0
Traj_Accel_Limit
float32
rev/s^2
accel_limit
4
Traj_Decel_Limit
float32
rev/s^2
decel_limit
Set_Traj_Inertia
  • Command ID: 0x13
Start Byte
Name
Type
Unit
Description
0
Traj_Inertia
float32
Nm/(rev/s^2)
inertia
Get_Iq
  • Command ID: 0x14
Start Byte
Name
Type
Unit
Description
0
Iq_Setpoint
float32
A
Iq_setpoint
4
Iq_Measured
float32
A
Iq_measured
Get_Temperature
  • Command ID: 0x15
Start Byte
Name
Type
Unit
Description
0
FET_Temperature
float32
deg C
<axis>.motor.fet_thermistor.temperature
4
Motor_Temperature
float32
deg C
<axis>.motor.motor_thermistor.temperature
Reboot
  • Command ID: 0x16
Start Byte
Name
Type
Description
0
Action
uint8
0: reboot()
1: save_configuration()
2: erase_configuration()
3: enter_dfu_mode2()
Reboots the ODrive according to Action. This requires the axis to be in IDLE.
  • Command ID: 0x17
Start Byte
Name
Type
Unit
Description
0
Bus_Voltage
float32
V
vbus_voltage
4
Bus_Current
float32
A
ibus
Clear_Errors
  • Command ID: 0x18
Start Byte
Name
Type
Description
0
Identify
uint8
identify
Equivalent to calling clear_errors().
  • Command ID: 0x19
Start Byte
Name
Type
Unit
Description
0
Position
float32
rev
pos_estimate
See also Custom User Reference Frame.
Set_Pos_Gain
  • Command ID: 0x1a
Start Byte
Name
Type
Unit
Description
0
Pos_Gain
float32
(rev/s) / rev
pos_gain
Set_Vel_Gains
  • Command ID: 0x1b
Start Byte
Name
Type
Unit
Description
0
Vel_Gain
float32
Nm / (rev/s)
vel_gain
4
Vel_Integrator_Gain
float32
Nm / rev
vel_integrator_gain
Get_Torques
  • Command ID: 0x1c
Start Byte
Name
Type
Unit
Description
0
Torque_Target
float32
Nm
effective_torque_setpoint
4
Torque_Estimate
float32
Nm
torque_estimate
Get_Powers
  • Command ID: 0x1d
Start Byte
Name
Type
Unit
Description
0
Electrical_Power
float32
W
electrical_power
4
Mechanical_Power
float32
W
mechanical_power
Enter_DFU_Mode
  • Command ID: 0x1f
  • Empty Payload
Puts the ODrive into DFU mode (see Firmware Update). Equivalent to calling enter_dfu_mode2().
